Activity Forums Apple Final Cut Pro Legacy Slight OT – Networking with PC
  • Slight OT – Networking with PC
    Posted by Darren Kennedy on July 5, 2005 at 11:21 pm
    I have a PC on the same network as my FCP system. I don’t have any problems going back and forth between the two machines except for ref. mov. files. I am assuming they won’t work cross platform but I just wanted to ask before I give up.
    Reason I want to do this is for .wmv compression. I currently render out a BM 8bit file from FCP and drag the resulting huge file over the network to the PC and use Procoder. It would be nice if I could just use a ref file.
    Darren
    Darren Kennedy replied 21 years, 1 month ago 4 Members · 4 Replies
  • Sean Oneil
    July 6, 2005 at 4:04 am
    Have you tried saving the reference file to shared folder on the Mac, and then accessing it and opening it from the PC?
  • Jerry Hofmann
    July 6, 2005 at 11:22 am
    What happens when you attempt a reference movie?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark023
    July 6, 2005 at 1:23 pm
    Flip4Mac, https://www.flip4mac.com/flip4mac_home.htm, has software that will enable you to export FCP files to .wmv. I just got it yesterday and it seems to work great.
  • Darren Kennedy
    July 6, 2005 at 8:22 pm
    Jerry – I tried a ref file and it shows up as an unsupported file on the PC.
    Mark – I tried Flip for Mac, and it does great .wmv files. Problem is time and flexibility. Procoder lets me do an avi, mpeg1 and wmv file as a batch. To do the same on the Mac would require me to use compressor for the mpeg1 file and still export to the PC for a good quality avi and .wmv. I might look at compression master on the mac if I can’t get the ref file to work over the network.
    Thanks to all for the ideas and suggestions.
    Darren
