Activity › Forums › Blackmagic Design › Slight monitoring problem with Decklink Extreme
  • Slight monitoring problem with Decklink Extreme
    Posted by Julian Clarke on May 23, 2005 at 7:00 pm
    Hi Guys,
    I switched from the Decklink 2, to the Decklink Extreme over a month ago. Since switching, I’ve had a sporadic problem with my component outs on the Decklink Extreme’s breakout cable. Occasionally I see several semi-transparent shimmery lines on my video monitor, over my picture. I can still see the picture behind it, but they are not fun to try to edit with. They will then will not go away until I start messing around with the cables, usually unhooking the breakout cable from the monitor and then reattaching them solves the problem (for a while). I wasn’t having any monitoring problems before with the Decklink 2 and my AJA DA, but now that I’m using the Extreme, I have this issue. So, I’m not sure if this is a problem with the breakout cable. A problem with the monitor or what. Anyone have any suggestions for addressing this problem?
    Cheers
    Julian
    Peter replied 21 years, 4 months ago 3 Members · 5 Replies
  • Peter
    May 24, 2005 at 11:23 am
    Hey Julian,
    I started to get this too recently after using an Extreme card for 5 months. By any chance do you have external media drives sitting next to your monitor? I moved mine away from the monitor and haven’t seen the lines since (just 2 days – fingers are crossed). There are some other posts here about “interference” that touch on the probelm too. Let us know if you figure it out…
  • Julian Clarke
    May 24, 2005 at 4:17 pm
    Thanks for your response.
    No, I don’t have any external drives near my monitor. I do have a mixer and a shielded speaker near it however. If I get some longer cables I could experiment with moving these things further away. I’ll let you know what the result is…
  • John Christie
    May 24, 2005 at 5:15 pm
    Hi Julian
    I’ve seen RF interference on another Decklink Extreme in Vancouver. Make sure you have no power cords crossing or running parallel with your Decklink breakout cable.
    Cheers
    John Christie
    Keyframes Editing
  • Julian Clarke
    May 25, 2005 at 4:12 pm
    So far so good. Removing the power cords crossing the breakout cable seems to have solved the problem.
    As always, you are a fountain of useful information John.
    Much obliged…
    Julian
  • Peter
    May 25, 2005 at 5:09 pm
    Hey Julian,
    Could you report back if the problem creeps up again for you. I’ve had this exact problem come-and-go for 6 months now and I’d love to find out for sure if it’s cable interfearance.
    Thanks in advance.
