Activity Forums Apple Final Cut Pro Legacy Slideshow replication in FCE & LT
  • Slideshow replication in FCE & LT
    Posted by Dunwoody Lampton on September 10, 2008 at 10:20 pm
    Will any feature(s) in Final Cut Express HD 3.5.1 and/or
    LiveType allow “zooming” in and out of various areas of
    J-peg files, similar to the features of “slideshow” software?
    Miriam Moran replied 18 years ago 3 Members · 3 Replies
  • Zane Barker
    September 11, 2008 at 5:10 am
    Yes you can do it in FCE by key framing every picture but if you use Fotomagico it will save you a TON of time
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Dunwoody Lampton
    September 11, 2008 at 9:06 am
    Thanks Zane. I will look into that.
    Just to confirm, I read through the ops manual
    and could only find reference to moving the
    clip WITHIN THE FRAME, not moving WITHIN
    THE PICTURE.
  • Miriam Moran
    September 14, 2008 at 11:09 pm
    In the motion tab of your viewer, there are controls for zooming and panning – use “scale” to make the picture larger/smaller, and you can use “center” to change where the center of your picture is. Both of these properties are keyframable – so you could, for example, begin a picture zoomed in on the top-left corner of the picture then zoom out toward the bottom right by
    increasing scale and moving the picture (drag it with your mouse to the desired postition in the canvas), keyframe both settings,
    move your playhead to the end of your picture, use scale to zoom out and move the center to affect position – FC should create those keyframes for you
    play your clip – you should see that motion occurring.
    Use of 3rd party software can be quicker, but I’ve done tons of photo montage type things in this manner and it is pretty straightforward once you get the hang of it.
