Activity › Forums › Adobe After Effects › Slideshow Issue
  • Slideshow Issue
    Posted by Richard Swinard on September 6, 2008 at 2:23 pm
    Hi all, this is my first post so can I say thank you for the After Effects resources available on this site, plus the legendary Andrew Kramer tutorials – they are priceless!
    I’ve been creating and rendering slideshows and have had no issues however yesterday I rendered a larger than normal (output file size 60gb) slideshow and had a number of issues during playback including stuttering image transition, audio clipping and general poor playback.
    The output settings used are:
    Format: Video for Windows (lossless)
    Video Output: Channels RGB
    No compression
    Machine specs:
    2.4GHz dual core
    4GB RAM
    Can you suggest anything that can assist me on this one, perhaps changing some of the other rendering settings?
    Thanks in advance for any help,
    Rich
    Richard Swinard replied 18 years ago 2 Members · 3 Replies
  • Chris Wright
    September 9, 2008 at 1:51 am
    let me get this straight, your slideshow is 60 GB? Sounds like your single hard drive won’t be able to do realtime playback.
  • Richard Swinard
    September 10, 2008 at 10:45 pm
    Yes it’s a 10 minute slideshow and the rendered file is circa 60GB. Maybe my orifinal image sizes are too large? What sort of res would you recommend if my intention is for the production to be rendered onto DVD for viewing on tv – is 800×600 too large?
    I did try rendering and compressing using a codec which isn’t ideal but the outfile file size was reduced substantially to around 450mb and the playback was fine.
    Rich
  • Richard Swinard
    September 21, 2008 at 10:25 pm
    Thanks for your response Dave, I have managed to get this going the way I wanted following your advice.
    Much appreciated,
    Richard
