Activity Forums DaVinci Resolve Slideshow image problems
  • Slideshow image problems
    Posted by Eng thye Kam on June 13, 2019 at 1:49 pm
    Using DaVinci Resolve 15 free version.
    Trying to make a 70 picture video slideshow with music from all .jpg format files.
    Notice that the .jpg files when imported into the media pool, turned into three types, no. 1 was images with a red bar at the bottom of the picture, no. 2 was a timeline file with a white cinderblock shaped icon at the bottom left corner and a red triangle with a tick mark inside it on the top right hand corner and no. 3 was an image without the red bar at the bottom.
    The type no. 1 was successfully transferred to the Video 1 timeline, the type no. 2 could not be transferred to the Video 1 timeline with a round “stop” icon appearing, the type no. 3 image shrunk when unsuccessfully transferring to the Video 1 timeline with a blue vertical bar appearing on the left of the image.
    What went wrong?
    Any help is much appreciated. Thanks.
    Eng thye Kam replied 7 years, 2 months ago 2 Members · 2 Replies
  • Marc Wielage
    June 13, 2019 at 10:16 pm
    JPGs will work, but they’re not an ideal file format for Resolve. The added compression will not help, either.
    I think you’re better off with TIFF or DPX files. If you can batch-convert all your stills to this format, I think it will work better.
  • Eng thye Kam
    June 14, 2019 at 11:43 am
    Thank you very much for your advice. I did a batch conversion to TIFF files using XnConvert and was able to make the slideshow video without any file problems using TIFF files.
    Thank you very much once again.
