Activity Forums Adobe Photoshop Slideshow descriptions
  • Slideshow descriptions
    Posted by Douglas R bruce on April 4, 2007 at 2:22 am
    Sorry if this is answered elsewhere – but I couldn’t find it.
    I created a “Horizontal Slide Show” with Photoshop CS2.
    I used Dreamweaver to upload it to my site.
    No problems so far.
    Then I used Dreamweaver to edit the “Description” on each .htm page – I thought that the description would then change as each slide changed – but no!
    The description of the first slide is seen of each following slide.
    Am I expecting too much of the slideshow?
    Anyone point me in the correct direction to have a different description for each slide?
    Maybe I should choose one of the other automated slide show scripts?
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
    Douglas R bruce replied 19 years, 5 months ago 1 Member · 1 Reply
  • Douglas R bruce
    April 4, 2007 at 5:15 am
    While the USA was asleep I searched around from japan and found the answer to my question.
    In case anyone else has this problem here is the answer.
    The Slide show needs to read the pictures Metadata.
    So first of all I had to fill in each images metadata description box.
    Then, seemingly, just this HorizontalSlideShow has a problem which is fixed by “ticking” for all the choices in the “thumbnail” section. Even if you are not going to write any info there…you should check them all.
    Problem solved!
    Thank you, Douglas.
    Don’t mention it……. smile.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
