Activity Forums Adobe After Effects Slideshow automation
  • Slideshow automation
    Posted by Kurt on May 8, 2005 at 2:50 am
    I’m making a wedding video…
    I want to test the pacing and feel of the over all piece – i’m making a slide show right now. all the source images are different sizes. is there a way to automate the scaling and fade in / fade out of 100 images. I want to apply the same effet to each layer, then just sequense them. I though of making a favorite, but that doesn’t work for scale shifts if the layers are diffrent size…?
    Kurt
    Joe Chao replied 21 years, 3 months ago 2 Members · 3 Replies
  • Joe Chao
    May 8, 2005 at 3:30 am
    1:Creat a new composition
    2:put all your images into this composition
    3:select all the layers and push:alt+ctrl+F
    4:right click the layers and click :Keyframe assistant/Squence layers
    5:fill in your requirement about fading in/out
    6:click OK
    7:if you want to appply some effect for them,select one layer,then apply the effect and adjusting it,after that you can copy the effect and paste it to all other layers
    My name is always misread as COW……..:)
    friendcao2004@hotmail.com
  • Kurt
    May 8, 2005 at 10:37 am
    thanks for the tips
    what does alt-cntl-F translate to on the mac? the only key cmds i know all stretch the images to fit the comp – with tweaks the porportion
  • Joe Chao
    May 8, 2005 at 11:54 am
    Try this:apple+alt(option)+f
