Activity › Forums › Adobe Premiere Pro › Slideshow
  • Slideshow
    Posted by Nancy Katkin on October 18, 2014 at 12:32 pm
    I have a bunch of 1600 x 1200 still images (both portrait and landscape) and a few 720 x 480 images that I am trying to make into a slideshow in Premiere Pro, and that will eventually be placed on YouTube. The only 4:3 DVD format I can find is 720 x 480, and the images look really rastered. What am I doing wrong?
    Daniel Waldron replied 11 years, 11 months ago 2 Members · 3 Replies
  • Daniel Waldron
    October 18, 2014 at 7:33 pm
    Why are you making a 4:3 DVD format for YouTube? What are your sequence settings and what are your export settings? Those will both affect the final output.
  • Nancy Katkin
    October 19, 2014 at 2:29 pm
    My apologies for being such a newbie at this… But, I am using 4:3 because most of the photos are 1600 x 1200–same ratio? My sequence settings are: 720 x 480; PAR=D1/DV NTSC (0.9091); 29.97 fps. My export settings are: H.264; YouTubeSD. Thanks SO much for your expertise Daniel.
  • Daniel Waldron
    October 19, 2014 at 4:17 pm
    No apologies necessary. This is what the forum is for 🙂
    4:3 is fine for the aspect ratio if you want your photos to fill the frame. YouTube will add black bars on the side when you upload it to make it fit their 16:9 player. Other than being standard definition, I’m not sure why your export would look extra pixelated. Your Pixel Aspect Ratio (PAR) should probably be set to “Square” instead of “D1/DV NTSC (0.9091)”. This isn’t going to DVD so there is no reason to use non-square pixels.
    I personally would recommend creating a HD 1280×720 sequence to work with. Since you say only a few of the photos are the 720×480, you can either leave these at that size and put a background behind them or try scaling them up and seeing how they look. Yes, there will be empty space on either size of your photo while you edit, but if YouTube is going to add pillar boxes (black bars) anyway, I think you are better off starting at a higher resolution.
