Activity › Forums › Adobe After Effects Expressions › Slider/Carousel with center fade on – yet controlled by null-movement
  • Slider/Carousel with center fade on – yet controlled by null-movement
    Posted by Manuel Moellmann on February 21, 2023 at 3:29 am
    Hey guys,
    right now, I cant really get my head around this. I hope one of you can help me. I bet its actually nothing crazy to change 😛
    I want to create a slider like this:
    https://i.imgur.com/pXhNNkB.gif
    I get how the code works and how to apply it to any kind of property, like in this case, the layers opacity:
    v = transform.position[0] // x
    d = length(v,thisComp.width/2);
    maxDist= 960; ease(d,0,maxDist,100,0);
    Unfortunately, it only gets triggerd if every single “slider-element” / layer gets actually moved by changing its position. – I would like to have it work by using a null thats handling the movement from left to right while its the parent of all the slider-elements.
    Now, if i parent a layer to a null and move it by moving the null, its position-coordinates remain untouched. – Does anyone of you guys know, how i can make the null position affect the position-coordinates of each layer? Would be much appreaciated!
    View post on imgur.com
    Manuel Moellmann replied 3 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 21, 2023 at 3:54 am
    v = toComp(anchorPoint)[0];
    should give you the x position of the layer itself.
  • Manuel Moellmann
    February 21, 2023 at 4:06 am
    thank you dan! I already thought it had to be done by using one of the, for me still unfamiliar, “toComp…” variants. Thanks a lot! Its crazy to see how much effort you put into helping fools like me on the web. Great to have such an experienced and kind guy like you around!
