Activity Forums Adobe After Effects Slider: visual response those not change
  • Slider: visual response those not change
    Posted by Max Arch on February 10, 2016 at 9:31 pm
    I have a slider if I change it with not key frame, I see the action of the slider.
    But if I do key frame the visual those not change any more , it stays at the first value.
    but the slider numbers change true time but with not visual impact
    Max Arch replied 10 years, 7 months ago 2 Members · 6 Replies
  • Walter Soyka
    February 10, 2016 at 10:34 pm
    What’s the expression that’s controlling the size and referencing the slider?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Max Arch
    February 11, 2016 at 4:22 am
    this is the expresion
    it on a other comp
    comp(“eye main”).layer(“eye controller”).effect(“iris control”)(“Slider”)
  • Walter Soyka
    February 11, 2016 at 11:43 am
    [max arch] “it on a other comp”
    Are the comps offset in time? In other words, does the first frame of your eye comp line up with the first frame of the controller comp that contains it, or is there a difference?
    This expression should work if the two comps share common time.
    Walter Soyka
  • Max Arch
    February 11, 2016 at 1:20 pm
    they have different time
    do you know a expression that work or it better for me to change the time of the comp
  • Walter Soyka
    February 11, 2016 at 1:28 pm
    Adjusting the time of the comp is the easiest way, but you can do it with expressions, too.
    As long as you know what the time offset is, you could use valueAtTime() to compensate. For example, if your precomp layer starts at 1 second in on the main comp:
    comp("eye main").layer("eye controller").effect("iris control")("Slider").valueAtTime(time+1)
    Walter Soyka
  • Max Arch
    February 17, 2016 at 6:51 pm
    I was able to make it work with your comment,
    both comp where the same time but I have moved one comp forward in the timeline.
    I have adjusted both at the beginning and it work.
    thanks for your help
