Activity › Forums › Adobe After Effects Expressions › Slider Values Based on Frame Rate
  • Slider Values Based on Frame Rate
    Posted by Chris Taylor on April 8, 2015 at 11:25 am
    Hi there,
    I was wondering if there was an expression that I could add to a slider that would lock its values to a time.
    For example, a standard slider goes from 1-100 and has decimal values from .01 to .99, is there an expression that would convert these values to whatever frame rate I wanted?
    So, instead of the decimal values being .01 to .99, they would be .01 to .30?
    Dan Ebberts
    replied 11 years, 5 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    April 8, 2015 at 3:52 pm
    I’m not sure if this is what you mean, but you can use linear() to remap a range of values, like this
    linear(value,.01,.99,.01,.30)
    Dan
  • Chris Taylor
    April 8, 2015 at 4:30 pm
    no that doesnt seem to work. It seems to lock the slider value to .30.
    It might just be a case of multipying the values by 3.33333….?
  • Dan Ebberts
    April 8, 2015 at 4:42 pm
    If you enter 0.5 for the slider value, you should get 0.16. Is that not what you wanted?
    Dan
    (edit)
    I just re-read your original post, and maybe this is what you’re after:
    linear(value,1,100,.01,.30)
