Activity Forums Adobe After Effects Expressions Slider Value Ratio
  • Slider Value Ratio
    Posted by Tudor Baican on November 19, 2022 at 8:01 pm
    Hello friends,
    I have in my setup two value sliders. One for the width and one for the height.
    With a checkbox I want to lock the ratio of the sliders.
    Then I just want to use the width slider to scale the height in the same ratio.
    I thing is easy but I don’t get it 😤
    var ratio = effect(‘Slider Width’)(‘slider’)/effect(‘Slider Height’)(‘slider’);
    effect(‘Checkbox Control’)(‘Checkbox’)==true ? effect(‘Slider Width’)(‘slider’)*ratio : value;
    Tudor Baican replied 3 years, 10 months ago 2 Members · 4 Replies
  • Dan Ebberts
    November 19, 2022 at 8:21 pm
    I’m assuming this expression would be applied to the height slider, is that correct? If so, then I think your ratio is backwards (should be height/width) but I don’t think it will work because both sides of your conditional calculate out to the same value (which is the current value of the height slider).
  • Tudor Baican
    November 19, 2022 at 8:33 pm
    Yes, it’s not woking. I use the height value to calculate the ratio and then it will changed in the next line at the same time. 😐
  • Dan Ebberts
    November 19, 2022 at 9:10 pm
    You might want to add a ratio slider that would get used when the checkbox is on.
  • Tudor Baican
    November 20, 2022 at 4:31 pm
    yes, had also this idea. But I use now a scale slider as multiplier, this works better.
