Activity Forums Adobe After Effects Expressions Slider to Play through keyframe data
  • Slider to Play through keyframe data
    Posted by Marticus Kilverticus on February 10, 2020 at 3:04 pm
    Hi all,
    I’m animating flashing opacity effects which I want to happen across a slider 0-1.
    So I have the flashing keyframe data (1-10 keys) on a separate layer’s opacity.
    How do I playthrough each keyframes data as the slider progresses through 0 – 1?
    Marticus Kilverticus replied 6 years, 7 months ago 2 Members · 4 Replies
  • Alex Printz
    February 10, 2020 at 8:41 pm
    try this, just point the effect correctly to the proper slider
    valueAtTime(linear(thisComp.layer("target layer").effect("Slider")(1),0,1,key(1).time,key(numKeys).time))
    Alex Printz
    Mograph Designer
  • Marticus Kilverticus
    February 10, 2020 at 9:56 pm
    It’s good, thank you!
    But I’m struggling to grab the keyframe information from a different layer when using the normal reference methods. How do I target my “opa” correctly in this instance below?
    row = effect("Row")("Slider");
    drop = thisComp.layer("CTRL").effect("Drop")("Slider");
    thedrop = linear(drop,row-1,row,0,1); //converts row vs drop to 0 to 1
    opa = thisComp.layer("Col A Row 1").transform.opacity //reference layers opacity
    valueAtTime(linear(thedrop,0,1,key(1).time,key(numKeys).time))
  • Alex Printz
    February 11, 2020 at 3:12 pm
    I think it would be like this:
    valueAtTime(linear(thedrop,0,1,opa.key(1).time,opa.key(opa.numKeys).time))
    Alex Printz
    Mograph Designer
    February 11, 2020 at 4:12 pm
    Many thanks Alex!
    That was nearly right, just needed another reference to the layer at the start! Phew! 😀
    opa.valueAtTime(linear(slider,0,1,opa.key(1).time,opa.key(opa.numKeys).time))
