Activity Forums Adobe After Effects Expressions Slider expression
  • Posted by Ryan Biercewicz on November 24, 2014 at 2:25 pm
    Bit of a complicated one this one, so apologies in advance if I don’t word this right!
    I have a source text layer, linked to a slider which I want to count up from 00.0000 to 11.1111. On my source text layer, I have the following expression;
    effect(“Slider Control”)(“Slider”).value.toFixed(4);
    Here’s the difficult part – I have a box animated from one side of the screen to another, and as that box starts and stops moving, I want the counter to start and end. I currently have the following expression added to my slider;
    thisComp.layer(“Box”).transform.position[0];
    However, I want the counter to read 00.0000 to 11.1111, not to use the X co-ordinates as it is currently doing. Is there a way to override the x co-ordinates and determine a start and end point for the slider’s numeric value, but still keep the link between the slider and the box’s position keyframe?
    Thanks in advance!
    Ryan
    effect("Slider Control")("Slider").value.toFixed(4);
    thisComp.layer("Box").transform.position[0];
    Ryan Biercewicz replied 11 years, 10 months ago 2 Members · 16 Replies
  • 16 Replies
  • David Conklin
    November 24, 2014 at 4:37 pm
    You can use linear interpolation to do this. Essentially ‘mapping’ the X-val of your Box to the slider. What this does, basically, is say when Box is at position 0, slider should be 0, when box is at thisComp.width, slider is 11.1111. The beauty of this expression is that it ‘tweens’ all the values between those two states.
    The last line of this expression simply makes sure that the slider never exceeds 11.1111 or goes below 0 (which may happen if your box goes into negative or past the width of your comp).
    Of course, you can update all of these values to fit your case sepecifically.
    Check out the below expression. Happy coding!
    //this goes on your slider.
    //get the thing we're tracking.
    var cntrl = thisComp.layer("BOX").transform.position[0];
    var boxStartX = 0 //box starts at 0;
    var boxEndX = thisComp.width //box ends at width of comp.
    var sliderStart = 0; //slider begins at 0.
    var sliderEnd = 11.1111; //slider ends at 11.1111.
    //make the interpolation.
    var makeSlider = linear(cntrl, boxStartX, boxEndX, sliderStart, sliderEnd);
    //clamp the value (don't let it go out of range)
    Math.min(Math.max(sliderStart, makeSlider), sliderEnd)
    David Conklin
    Motion Designer
  • Ryan Biercewicz
    November 24, 2014 at 4:59 pm
    Hi David,
    Wow this is fantastic, thanks so much! The only problem is that it doesn’t reach 11.1111 at the end of the move, it counts up and then stops at 6.7949 when the box finishes moving.
    Am I doing something wrong?
    Cheers
    Ryan
  • Ryan Biercewicz
    November 24, 2014 at 5:00 pm
    To clarify, this is the expression I pasted onto my slider;
    var cntrl = thisComp.layer(“box”).transform.position[0];
    var boxStartX = 0
    var sliderStart =0;
    Math.min(Math.max(0, makeSlider), 11.1111)
  • Ryan Biercewicz
    November 24, 2014 at 5:05 pm
    Sorry David, I’ve just figured out why that’s happening – the expression is dependent on the width of the comp.
    Unfortunately, the box doesn’t travel all the way across the comp – I still need it to read 11.1111 at it’s final destination, is there a modification I can make to enable this?
    Cheers
    Ryan
  • David Conklin
    November 24, 2014 at 5:37 pm
    Yeah, no problem. The line you’re looking for is this:
    Simply change that to your box’s end X position and you should be good! For instance
    var boxEndX = 985; //box ends at X=985.
    Good luck!
    David Conklin
    Motion Designer
  • David Conklin
    November 24, 2014 at 5:50 pm
    Another trick would be to link the boxEndX variable to the last keyframe of your box’s position value, that way you don’t have to change the expression if you decide to redo the box animation. The expression is a little different, and would look like this:
    var cntrl = thisComp.layer("BOX").transform.position;
    //define holders
    var boxStartX;
    var boxEndX;
    //check to make sure there are keyframes
    if(cntrl.numKeys > 0){
    //get keyframe values.
    boxStartX = cntrl.key(1).value[0];
    boxEndX = cntrl.key(cntrl.numKeys).value[0];
    } else {
    //if no keyframes, fall back on these values
    //(change them to whatever you need.)
    boxStartX = 0;
    boxEndX = 500;
    //slider values
    var makeSlider = linear(cntrl[0], boxStartX, boxEndX, sliderStart, sliderEnd);
    Math.min(Math.max(sliderStart, makeSlider), sliderEnd);
    The clamp is only necessary in case you have a/some middle keyframe(s) that go outside of the range set by your first and last keyframes.
    Good luck!
    David Conklin
    Motion Designer
  • Ryan Biercewicz
    November 24, 2014 at 6:00 pm
    Hi David,
    Ah perfect, thanks!
    Just one final thing – do you know if theres a way to ease the counter, so that when the box eases out of the move the counter eases to the final number? There are a few ‘counter-ease’ expressions online but they all seem to be dependent on duration – this one is obviously based on comp width so I was wondering if there’s a solution to this?
    Cheers,
    Ryan
  • David Conklin
    November 24, 2014 at 6:13 pm
    Heya – this expression is getting its data from the X position, yeah, but it’s still using an interpolation function to do so.
    While the default easing settings for this function are somewhat limited, you can do a regular easy-ease, ease-in or ease-out simply by changing the above line to something like this:
    var makeSlider = ease(cntrl, boxStartX, boxEndX, sliderStart, sliderEnd);
    var makeSlider = easeOut(cntrl, boxStartX, boxEndX, sliderStart, sliderEnd);
    var makeSlider = easeIn(cntrl, boxStartX, boxEndX, sliderStart, sliderEnd);
    Keep in mind that the expression is tracking the box’s progress as it moves between two points. This means that the easing applied to your box is already being applied to the slider. You could try to more heavily ease the box animation if you need a more eased slider. Using one of the ease() functions above will strengthen the ease applied to the slider, though.
    Good luck!
    David Conklin
    Motion Designer
  • Ryan Biercewicz
    November 24, 2014 at 6:41 pm
    Hi David,
    This is great, thanks so much for solving this one! It’s working perfectly now – just a note, I had an error come up with the ease expressions but tried adding a [0] after cntrl as you did before, and that seemed to sort it out.
    Cheers,
    Ryan
  • Ryan Biercewicz
    November 25, 2014 at 2:18 pm
    Hi David,
    I’ve run into another problem – I now have a box travelling along the Y axis (from bottom to halfway up the screen), but I can’t figure out the modifications I need to make to the expression. If I change the X to Y values it doesn’t seem to work. What am I missing?
    Best,
    Ryan
