Activity Forums Adobe After Effects Slider effect problem
  • Slider effect problem
    Posted by Thom Buiting on January 3, 2018 at 1:09 pm
    Hi all,
    Currently I’m working on a animation but something isn’t working out.
    I have one text layer (SHOTSPEED 0 KM/H). In this layer I want “0” to slide up to “100”.
    If I use Slider Control it affects the whole text layer which is not what I want because then I’ll lose the words.
    Does anyone know how to put the Slider Control (or something similar) only on the 0 without using multiple layers? If I use multiple layers I can’t get the spacing between the words right.
    Hopefully someone knows the answer ????
    Cheers,
    Thom
    Thom Buiting replied 8 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 3, 2018 at 5:14 pm
    You need to use an expression that includes the value of the slider inside your text string, like this:
    "SHOTSPEED " + parseInt(effect("Slider Control")("Slider")) + " KM/H"
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Thom Buiting
    January 3, 2018 at 5:28 pm
    Thanks Walter, that’s just wat I needed! ????
