Activity Forums Adobe After Effects Slider controling Slider Expression
  • Slider controling Slider Expression
    Posted by James Ronan on November 24, 2015 at 3:41 pm
    Hey guys.
    I have a slider attached to ObjectA animating it’s Y scale – This works fine.
    I also have a slider on seperate Null layer.
    What I then want is to have the slider on the Null layer control the overall % of the slider on ObjectA without messing up the keyframes it has.
    E.g:
    If ObjectA slider is at 300.
    A Null Layer slider is at 50
    The scale of ObjectA will be 150
    Any help much appreciated.
    I’ve been looking into the linear expression which I feel is close but I cant work it out.
    J
    James Ronan replied 10 years, 9 months ago 2 Members · 2 Replies
  • John Cuevas
    November 24, 2015 at 4:57 pm
    if it’s for scale, you could do it like this:
    x = thisLayer.scale[0];
    y = effect("Slider Control")("Slider");
    yFinal = y * (thisComp.layer("Null 1").effect("Final Adustment")("Slider")/100);
    [x,yFinal]
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • James Ronan
    November 24, 2015 at 5:25 pm
    Wow!
    Thanks so much for the fast reply! This is a nice work around!!
    Much Appreciated !!!
