Activity Forums Adobe After Effects Expressions Slider Control values
  • Slider Control values
    Posted by Matthias Gottung on May 29, 2006 at 4:00 pm
    Hey Everyone,
    I have another Problem, this time it’s regarding expressions and slider controls.
    I want to move objects from right to left and the slider should work like an multiplication value
    So if I move the slider from 1 to 2 the movement should be 2 times faster
    I used this line and it worked at first.
    [time*thisComp.layer(“Control”).effect(“Layer”)(“Slider”),340]
    the problem is when I set keyframes for this everything works fine for the time between 2 keyframes
    after the keyframes the movement is slower then it should be
    After checking through the values I came up with an idea what the problem might be.
    The keyframes of the slider only submit relative information instead of the absolute values.
    For example if I would set 2 Keyframes, with the values 0 and 50 at 0 and 50 frames
    After Effects would submit:
    frame 1=1 frame 2=2 frame 3=3 and at frame 51=0
    Because After effects has reached the “value” of 50 at frame 50 and is no longer sending information
    But if after effects would send:
    frame 1=”Slider value” frame 2=”Slider Value” …
    then the speed wouldn’t go down after the last keyframe because the slider would still send information.
    Ok that was as clear as I can formulate my problem.
    I could send my project file via e-mail if it could help
    with kind regards
    Matthias Gottung replied 20 years, 3 months ago 2 Members · 2 Replies
  • Mylenium
    May 29, 2006 at 4:25 pm
    Nope, your logic is wrong. The behavior is just fine. You are forgetting that by animating your sliders in sync with time your are creating an exponential function, not a linear multiplication. Once you stop changing the values, the exponential behavior will become more and more linear. A simpler and more efficient function would be
    Math.pow(time,2)
    without any sliders (assuming you want to double your values every second).
    Mylenium
    [Pour Myl
  • Matthias Gottung
    June 2, 2006 at 1:14 pm
    Hey Mylenium,
    Well, I didn’t what to use an exponential function. I just wanted to multiplicate the time value
    with the value that was controlled with the slider.
    Sorry for the delay
    Mogamblin
