Activity › Forums › Adobe After Effects Expressions › Slider control to switch between three fill colors
  • Slider control to switch between three fill colors
    Posted by Nicholas Deines on August 6, 2020 at 6:06 pm
    Hello,
    Is it possible to pick whip a fill color to a slider control and then have that color change based on the slider number? “1” would be connected to fill color 1, “2” would be connected to fill color 2. I have a US Map with each state isolated. My goal is to build an essential graphics panel that allows me to quickly set a group of states to the same color by choosing a “1”, “2”, or “3” on a slider.
    I’ve seen other posts on defining display colors based on a slider value using if/else expressions. But those colors are set. I want my color to be changeable via a fill in a null.
    Filip Vandueren replied 6 years, 1 month ago 2 Members · 1 Reply
  • Filip Vandueren
    August 6, 2020 at 8:08 pm
    So there would be 50 sliders, one for every state ?
    And 3 colors on the essential graphics ?
    Would the colors also need to fade in fade out? Or you would do that by animating the master property of the color?
