Activity Forums Adobe After Effects Expressions Slider Control to adjust position
  • Slider Control to adjust position
    Posted by Benjamin Taylor-day on April 5, 2013 at 5:06 pm
    Hi, Im very new to AE, but im currently learning expression controls.
    Im working on an animation on a character where i want the ear move between 2 points, A = 1088, 766 and B = 980, 952, rather than moving the ears manually each time i would like to use a slider control.
    I’ve tried pick whipping “position” to the slider but that just moves the ear to 100,100 and when i move the slider it moves the ear up and down equally 101,101 – 102,102 – 103,103 etc etc)
    Is their a way to create a pre-defined path for the object to follow using the slider?
    I hope ive made sense. All new and complicated to me.
    Ben
    Dan Ebberts replied 13 years, 4 months ago 2 Members · 5 Replies
  • Dan Ebberts
    April 5, 2013 at 5:53 pm
    This will move the layer between A and B as the slider goes from 0 to 100:
    s = effect(“Slider Control”)(“Slider”);
    A = [1088,766];
    B = [980,952];
    linear(s,0,100,A,B)
    Dan
  • Benjamin Taylor-day
    April 5, 2013 at 6:10 pm
    Thanks Dan!
    Ive put that into the expression box for “position” on the ear layer? Is that right as i get an “expression disabled error?
    Would you be able to explain what that code “means”, so i can try and get my head around expressions.
    Thank you again 🙂
    April 5, 2013 at 6:12 pm
    Oh wait, ive sorted it! I just had to pick whip the “effect(“Slider Control”)(“Slider”);” bit!
    April 7, 2013 at 1:55 pm
    Would i have to do anything different if i wanted this movement controlled by the angle control so position A = 0 and position B = 360?
    Ive tried this code but it doesnt work:
    s = thisComp.layer(“Control”).effect(“Ears”)(“Angle”);
    A = [1088,766];
    B = [980,952];
    linear(s,0,360,A,B);
  • Dan Ebberts
    April 7, 2013 at 4:30 pm
    It works the way I would expect it to. What does is it doing for you? Are you getting an error message?
    Dan
