Activity Forums Adobe After Effects Slide Show Frame Rate?
  • Slide Show Frame Rate?
    Posted by Randyrandy on October 28, 2005 at 1:06 pm
    I created a slide show in AAE with the following Composition Settings:
    720 x 480
    Aspect ratio: DV NTSC 0.9
    Frame rate 2
    Resoultion full.
    But when I try to import into Encore dvd it wants Frame Rate to be 30fps or 24p.
    How do I go about this? I want to have a picture slide/gallery on dvd as another chapter.
    thanx
    Randyrandy replied 20 years, 10 months ago 2 Members · 2 Replies
  • Andrew Yoole
    October 28, 2005 at 3:11 pm
    After Effects is a video compositing tool, not a DVD authoring tool. Create the slideshow within Encore DVD.
  • Randyrandy
    October 29, 2005 at 5:13 pm
    Thanx.
    I know what After Effects is, I just didn’t know how to deal with still images (frame rate issues in order to create a slide show 1-3fps vs. 30fps).
    Anyways. I found a solution on Adobe web: https://www.adobe.com/support/techdocs/317681.html
    and I successully created and output what I wanted from After Effects.
    I thank you for your time though.
