Activity Forums Apple Final Cut Pro Legacy slide in effect in FCP
  • slide in effect in FCP
    Posted by Jared Smith on September 24, 2010 at 6:02 am
    I have no idea if there is going to be a way to communicate what I want and what I have on this footage.
    Basically, if you go to this link, you will see the short clip I am working on. When “suit and tie” character walks into the room and the footage of that clip slides over it appears to reveal the footage of “non suit” character as if it was a layer under… What I am wanting instead is when the “suit and tie” character’s footage starts to slide it pulls in the other footage of the non suit with it as if the right corners of suit footage is pulling the left corners of non suit footage until they rest at split screen…
    Does this make sense at all???
    here is the link to the footage:
    https://vimeo.com/15244941
    Rafael Amador replied 16 years ago 2 Members · 1 Reply
  • Rafael Amador
    September 24, 2010 at 7:26 am
    Hi Jared,
    In the moment the Tie guy clip starts to slide to the left, the no-tie guy must be with the center right on the left border.
    In the moment the tie guy stops, the no-tie guy must have the center in “0,0”.
    So just two key-frames (on Center)in at the same time in both layers.
    rafael
    PS: This is a very basic question.
    http://www.nagavideo.com
