Activity › Forums › Apple Final Cut Pro Legacy › Slicing up QT re-import
Posted by Bernard Lyall on February 22, 2010 at 1:02 pmHi, I’m exporting my seq to QT and back again, before sending to Color (it’s not so long and makes sense to avoid any gremlins). Is there a quick way to chop it up into its shots again, or do i have to go through with the razor-blade?
Cheers,
Bernard
Michael Gissing replied 16 years, 7 months ago 4 Members · 5 Replies -
Rafael Amador
February 22, 2010 at 2:12 pm[Bernard Lyall] “I’m exporting my seq to QT and back again, before sending to Color (it’s not so long”
So why to waist a generation?
Rafael -
Jeremy Garchow
February 22, 2010 at 2:26 pmAgreed. Why do this?
If you insist, no, there’s no quick way to chop it back up, you must do it by hand.
Bernard Lyall
February 22, 2010 at 4:13 pmThe why is because i just wanted to be sure there wasn’t anything left in the timeline – filters, motion effects or whatever – that might mess up the process. I’ve fallen foul of this before and ended up with Color trying to render entire tape-length sources. It didn’t take long to export. Or to chop up, now I’ve done it by hand.
Jeremy Garchow
February 22, 2010 at 4:29 pm[Bernard Lyall] ” filters, motion effects or whateve”
Fliter get ignored in Color and replaced after you grade. Motion effects (speed changes) need to be baked in, which will probably be a lot faster than exporting and chopping back up.
[Bernard Lyall] “I’ve fallen foul of this before and ended up with Color trying to render entire tape-length sources.”
Baking in speed changes will fix that.
Walter made this just for you:
https://library.creativecow.net/articles/biscardi_walter/fromfcp2color.php
Michael Gissing
February 22, 2010 at 8:58 pmAlso you will not have any shot handles after the grade plus you may have fun grading across any dissolve transitions or fades to black (if you have any).
Just bake in the odd shot that has a speed change. I presume you are on an earlier version of Color than 1.5.1 if you are being so cautious although it pays to simplify and flatten the timeline anyway.
