Activity Forums Maxon Cinema 4D Sletch and Toon with Planes using alpha channels
  • Sletch and Toon with Planes using alpha channels
    Posted by Michael Goldberg on May 18, 2006 at 6:48 pm
    I’m using Sketch and Toon on a scene, and it’s looking good. I have several objects that are simple planes with alpha channels. When I render with S&T, it outlines the entire plane, and fills the transparent area with black. Is there any way to fix this easilly?
    Mike
    Adam Trachtenberg replied 20 years, 4 months ago 2 Members · 5 Replies
  • Adam Trachtenberg
    May 19, 2006 at 5:11 am
    You should be able to fix it by going into Effects>Sketch & Toon>Shading and turning off object shading.
  • Michael Goldberg
    May 19, 2006 at 1:01 pm
    Adam,
    As usual thank for your helpful posts…..
    Let’s say I want the object to have the shading. Anyway around this. I know I can import the original spline, and create a surface, but that might take a while..
    MG
  • Adam Trachtenberg
    May 20, 2006 at 11:19 pm
    [Michael Goldberg] “Let’s say I want the object to have the shading. Anyway around this. I know I can import the original spline, and create a surface, but that might take a while..”
    Hi Michael,
    I don’t understand the question. 🙂
  • Michael Goldberg
    May 21, 2006 at 10:16 pm
    If I turn off object shading, the object is shaded as it’s textured. I want it to have the cartoon shading that sketch and toon is applying, only not to the areas outside the alpha channel.
    Mike
  • Adam Trachtenberg
    May 21, 2006 at 11:25 pm
    [Michael Goldberg] “If I turn off object shading, the object is shaded as it’s textured. I want it to have the cartoon shading that sketch and toon is applying, only not to the areas outside the alpha channel.”
    I think I get it now. That doesn’t seem possible with the Effects>Shading, but you should be able to get something you like using the Sketch>Cel material.
