Activity Forums AJA Video Systems Slaving time code from one KiPro to another
  • Slaving time code from one KiPro to another
    Posted by Tom Matthies on August 26, 2012 at 10:06 pm
    I need to double record a show on a pair of KiPro recorders and would like matching rime code on each file. I’ve tried to set one KiPro as a “master” machine using internal time code and then set the second machine as a “slave” machine and taking time code from the first machine into the second machine and setting the time code source to external. I can’t seem to get the second machine to lock to the first machine. Is there a special trick? Seems that it should be pretty straightforward.
    E=MC2+/-2db
    Aja Sales department replied 14 years ago 2 Members · 1 Reply
  • Aja Sales department
    August 27, 2012 at 5:02 pm
    The Ki Pro LTC output does not provide output during EE or recording operations; the output is only for use during playback, as might be used for dubbing content to another device with matching timecode. For timecode to multiple Ki Pro units, the use of a timecode generator and a timecode distribution amplifier is recommended.
    This information can be found in the Ki Pro operation manual under the “LTC Timecode Input And Output” section. If you have additional questions, please feel free to contact AJA Technical Support via phone or email for assistance.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
