Activity › Forums › Maxon Cinema 4D › sla grass —- ??? — and illustrator problem —
  • sla grass —- ??? — and illustrator problem —
    Posted by Nicholas Toth on June 16, 2005 at 3:25 pm
    Anyone know how to make volumetric grass as a shader?
    And one other thing that i know i’m doing wrong, when i bring in illustrator files i wind up using booles on letters like e, o , p, you know letters with holes in them. how can you import the paths so the extrude tool recognizes the inside is negative space?
    rock and roll
    nicktoth
    Adam Trachtenberg replied 21 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 16, 2005 at 11:16 pm
    There’s a plugin called Storm Tracer that does volumetric grass (placard based).
    Regarding the splines, you should connect them before you extrude (Function>Connect (I think)).
