Activity Forums Adobe After Effects Expressions Skip frame to next visual frame if current frame is black
  • Skip frame to next visual frame if current frame is black
    Posted by Chris Huggett on September 26, 2007 at 1:45 pm
    Hi guys
    I have a BG of some neon lights shot. The vision is about 2.30 secs in length. The lights flicker great, but every now and again all the lights go out and leave black holes in the vision. Is it possible in AE7, to have an expression that is able to skip to the next visual frame, if the current frame is black.
    i just want to save myself some time instead of cutting up my footage and removing the black holes manually.
    Chris
    Chris Huggett replied 19 years ago 3 Members · 3 Replies
  • Lloyd Alvarez
    September 26, 2007 at 2:27 pm
    Sounds like a job for sampleImage which is unfortunately only available in CS3
    -Lloyd
  • Dan Ebberts
    September 26, 2007 at 2:28 pm
    Expressions in AE7 don’t have access to pixel color info. You could probably do it in CS3 with sampleImage() if you could define what constitutes a black frame.
    Dan
  • Chris Huggett
    September 26, 2007 at 5:47 pm
    Thank you gentlemen
