Activity Forums Avid Media Composer skip files when batch digitize
  • skip files when batch digitize
    Posted by Pol on November 7, 2006 at 9:53 pm
    I have a sequence, did a batch digitize but some clips were skipped. The original media was 15/1s so the clips that were skipped are still in that resolution. Now I want to re-digitize only the clips that are still in 15/1s. Is there an easy way to do that?
    I can’t delete the 15/1s media because I still use it for other projects. I don’t want to do a consolidate because it take to much time.
    I know, I know…next time I must use the decompose but for now I’m stuck.
    Sebastian Riezler replied 19 years, 10 months ago 3 Members · 2 Replies
  • Geraint Pari huws
    November 8, 2006 at 7:49 am
    unlink your 15.1 clips (alt relink)
    batch dig your sequence(off line media only)
    relink your media later when you nedd the 15.1
  • Sebastian Riezler
    November 8, 2006 at 10:26 am
    are all your files on the same drive?
    if not unmount the drive which contains the 15/1s media files.
    we always use seperate drives for our offline and online edits. so we just unmount the drive with the offline resolution and online the sequence to the online drive. then we cut the audiotracks of the offline sequence under it. done.
    rock on
    riot
