Activity › Forums › Maxon Cinema 4D › Skin Deformer Stretching Object? C4D R16
  • Brian Jones
    January 16, 2019 at 4:17 am
    it looks like you need to paint weights for your joints. It looks like the influence of the ‘bone’ there is too wide (which can happen) and if you paint the body vertexes with a weight of zero (for that bone/joint) the body won’t follow the arm.
  • Declan Haren
    January 16, 2019 at 5:43 pm
    Could you explain how to do that Brian? I tried a tutorial on YT for painting weights and i’m still having the same issue.
