Activity › Forums › Adobe After Effects › Skew 3d Text with after effects
Posted by Juan manuel Palomino domínguez on June 4, 2013 at 4:46 pmHi, i wonder about to skew a 3d text with after effects as you do with photoshop. Im not talking about an animate presets, i wonder about to do that in a no animated layer.
John Cuevas replied 13 years, 3 months ago 2 Members · 5 Replies -
John Cuevas
June 5, 2013 at 12:48 amTake your text layer and twirl it open and use the Animate flyout to skew the layer.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
June 5, 2013 at 10:47 amMay you explain your point better, cause i dont understand if youre talking about a tool or an effect. Im talking aboout doing this, te second line text:
https://www.google.com.ar/imgres?um=1&safe=off&sa=N&biw=1366&bih=664&hl=es-419&authuser=0&tbm=isch&tbnid=K3fYzyYRZiyyhM:&imgrefurl=https://forum.solidworks.com/thread/49261&docid=R1t7ciLu7qrxbM&imgurl=https://forum.solidworks.com/servlet/JiveServlet/showImage/2-256301-25035/Skew%252Btext%252Bproblem%252BSolidWorks.PNG&w=847&h=227&ei=9BavUZGdFJb64AOGt4DgAw&zoom=1&ved=1t:3588,r:0,s:0,i:79&iact=rc&dur=6117&page=1&tbnh=96&tbnw=360&start=0&ndsp=16&tx=86&ty=37It seem to be so simple, but in AE i dont know the way for doing this. Tank you.
John Cuevas
June 6, 2013 at 12:36 amCreate a line of text and open up it’s properties. There is a button(flyout) called “Animate”, select it. Now select “Skew”, when you do so, you will get a skew property you can animate.
Here’s a link to some basic tutorials on how to use the text animators in after effects, the first one in the series is “Animating Source Text” :
https://blogs.adobe.com/aftereffects/2012/02/after-effects-basics-tutorials-by-andrew-devis.html
John Cuevas
June 6, 2013 at 10:14 amGlad I was able to help.
