Activity Forums Maxon Cinema 4D Sketchy Pencil Animation
  • Sketchy Pencil Animation
    Posted by Carlos Cervantes on November 1, 2011 at 4:20 pm
    Hi, I’m new to Cinema 4D, and I’m self-learning everything I can doing all kind of tutorials around the web., but I haven’t been able to find one for the task I’m doing now.
    Also English is not my language so I’m sorry for any weird thing I say.
    I modelled a basic pencil, and I animated its position. I’m planning to export it as a PNG Animation and add it to a video I’m editing in AE.
    Basically I have two problems, the first one, is I don’t know how to make an animated, stroke effect using Sketch and Toon. Just a simple stroke, but sort of jumpy.
    The second one, is I’m having problems exporting PNGs with transparent background, when I use the sketch and toon effect.
    For Render Settings I’m using FORMAT:PNG, and in the SKETCH AND TOON options, in the SHADING options, I’m changing BACKGROUND from COLOR to OFF. But I’m always getting a black background in my png files.
    So, in short, I need to render only the stroke of the pencil, and with a jumpy animation.
    Thanks for your help!
    Adam Trachtenberg replied 14 years, 10 months ago 3 Members · 3 Replies
  • Randy Johnson
    November 1, 2011 at 4:38 pm
    For pencil strokes I have had pretty good results using a tracer object and a flat sweep nurbs connected to the tip.
    /Randy
  • Carlos Cervantes
    November 1, 2011 at 4:43 pm
    Thanks Randy,
    But maybe I didn’t explain myself, I don’t want the pencil to draw a stroke, but I need the pencil itself to look Pencil drawn. and look jumpy. I’m using the basic sketch and toon look, when applied to the object, but I need the borders to be glitchy.
  • Adam Trachtenberg
    November 1, 2011 at 5:50 pm
    Have you tried the presets in the Sketch Material’s Main tab? There are several pencil presets. I suggest you set the mode to Advanced, check out some of the presets, and then look at the settings they’re using to get a better idea what’s going on.
