Activity Forums Maxon Cinema 4D Sketch&Toon – Dashed line sliding
  • Sketch&Toon – Dashed line sliding
    Posted by Pravin Chottera on August 31, 2017 at 6:20 pm
    I’m using S&T to draw some dashed lines along a spline, but the dashed lines are slipping relative to the other objects in the scene.
    You can see how it slips relative to the boxes.
    I’ve played around with the stroke settings (start modes, clipping, etc) but can’t figure out how to fix the dashes along the spline.
    Scene file here: 11637_sttest.c4d.zip
    Any help would be appreciated!
    Brian Jones replied 9 years ago 2 Members · 1 Reply
  • Brian Jones
    September 1, 2017 at 2:17 am
    I don’t think so (but would be glad to be wrong) – the Help says “The Pattern settings give a pattern to the lines such as dashes or dots. These patterns are mostly useful for technical illustrations” To get what you want I think there would need to be a setting to control dash spacing based on depth but the only depth control is on thickness. I think the patterns are 2D only.
