Activity Forums Maxon Cinema 4D Sketch & Toon: Transparency
  • Sketch & Toon: Transparency
    Posted by Tom Slattery on November 29, 2005 at 12:30 am
    I was wondering if there is a way to make my translucent materials actually render that way with Sketch & Toon. I have found that although the material color changes when you tweak the tranparency slider, you can’t actually see through it at all.
    TPS
    Brian Jones replied 14 years, 9 months ago 4 Members · 4 Replies
  • Adamt
    November 29, 2005 at 6:30 am
    Go into Render>Effects>Sketch & Tune, and set object shading to “Off”. Should do the trick.
  • Tom Slattery
    November 29, 2005 at 3:07 pm
    That did the trick! Thank you very much!
    TPS
  • Matthew Dorris
    November 26, 2011 at 4:49 pm
    reving a nearly 7 year old thread here, but i’m having trouble getting the lines in the back of my transparent object to show through the transparency. For example, I have a 50% transparent rectangle, and the line shading is working for all the edges facing the camera on the outside of the rectangle, but when you look through it, you don’t see the lines in the back of the rectangle, further away from the camera.
  • Brian Jones
    November 26, 2011 at 5:19 pm
    you need to use the Default Hidden material in Render Settings/Sketch and Toon/Lines – you need to make (copy and paste or whatever) a second S&T material with different settings (less Opacity and/or different colour) to use as the hidden line material – you can use one material in both slots but the lines (both in front and back) will all be the same, which is ok of technical drawings but not good here so you’d need a second S&T mat.
