Activity Forums Maxon Cinema 4D Sketch & Toon: Forcing all lines to be rendered with selection tag not working
  • Kouraib Abdmalek
    February 9, 2026 at 8:41 am
    Hi Simon,
    I’ll come back later to investigate the cause, but I have an effective solution for this, and I use it successfully, especially when there’s no time to check the typology. you could convert the edges to Spline and then activate Spline in the tag as in the screen recording below. I hope this is helpful.
  • Simon Lucas
    February 9, 2026 at 10:21 am
    Hi Kouraib
    thank-you – that is a good working solution. If you have time to find the cause I would be interested, too.
    Regards
    Simon
  • Kouraib Abdmalek
    February 9, 2026 at 12:11 pm
    I’m glad that worked well for you. You can use this in various models; however, I’ll get back to your model as soon as I have the chance.
