Activity Forums Maxon Cinema 4D Sketch & Toon Changes With Resolution
  • Sketch & Toon Changes With Resolution
    Posted by Alexander Lieberman on July 30, 2019 at 5:19 pm
    Hi! I made a previous post for the same reason as this one. I’m a newb to Creative Cow, and couldn’t figure out how to upload my project file, so this is a second attempt.
    I have been trying to get my sketch and toon project to render how I set it up, and I would greatly appreciate any help I can get.
    I played with the thicknesses and cloned strokes, which looked great in the view I edited it in, but when rendering at low resolutions, those strokes and thicknesses are all messed up. I turned “resolution independent” on in the Sketch & Toon settings, and tried the XPresso Set Driver/Set Driven function, but I still cannot get this to work properly.
    I hope someone will be able to take a look and help. Thank you so so much!
    13596_sttower.c4d.zip
    Brian Jones replied 7 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 3, 2019 at 7:55 pm
    Distance Modifier added to to whatever parameters are necessary in the S&T materials. Here is a test with the Pink/Orange material (Mat) with the Spots shader in the Luminance turned off since it’s adding to the darkness but is harder to control since it doesn’t have a distance modifier I’m aware of, so only the three sketch mats are active. I added a Distance Modifier to each and then it’s a matter of controlling the distance parameter. It’s touchy but doable. Easier with a Perspective camera but it’s camera based control so if you are rendering from a non camera based view it doesn’t work and Parallel doesn’t work like perspective since the camera when moved closer will make the S&T thicker but doesn’t change the apparent closeness of the object.
    13604_sttower2.c4d.zip
