Activity › Forums › Maxon Cinema 4D › Sketch & Toon Changes When Rendered
  • Sketch & Toon Changes When Rendered
    Posted by Alexander Lieberman on July 28, 2019 at 11:09 pm
    Hi! I have been trying to get my sketch and toon project to render how I set it up for a while now, and I would greatly appreciate any help on this.
    I played with the thicknesses and cloned strokes, which looked great in the view I edited it in, but when rendering at my desired size, those strokes and thicknesses are all messed up. I turned “resolution independent” on in the Sketch & Toon settings, and tried the XPresso Set Driver/Set Driven function, but I still cannot get this to work properly.
    I’ve attached screenshots of what the project looks like rendered and not rendered. I might be overcomplicating things, but thank you so so much! :))
    Emir Bojorquez replied 7 years, 1 month ago 2 Members · 3 Replies
  • Emir Bojorquez
    July 30, 2019 at 4:36 pm
    You should share a demo file so someone can check it and help you
    Good luck
    Imagination is the best tool…
  • Alexander Lieberman
    July 30, 2019 at 5:20 pm
    Thank you for your advice Emir! I’ve made another post containing the project file.
  • Emir Bojorquez
    August 2, 2019 at 1:27 pm
    I’m not 100% sure to understand what you wanna get.
    But if this is what you are looking for, you need to adjuste the Thickness Distance:
    If, in the other hand, you wanna render the viewport, you need to change the Render to Software Open GL.
    Hope that helps.
    Good Luck
    https://pixldgblog.com
