Activity Forums Maxon Cinema 4D sketch – only see sketch lines
  • sketch – only see sketch lines
    Posted by Jonas Espinoza on January 31, 2007 at 12:26 am
    how do i disable the the shading on an object with a sketch tag.
    now i am seeing the sketch lines but with the basic default shading underneath.
    Jonas Espinoza replied 19 years, 7 months ago 3 Members · 3 Replies
  • Mylenium
    January 31, 2007 at 6:28 am
    Add your object to the exclusion list in the Render settings or use the S&T render tag.
    Mylenium
    [Pour Myl
  • Paul Coull
    January 31, 2007 at 3:52 pm
    Think this should do it:
    Get ‘Sketch and Tile tag’ and choose ‘shading’ then where it says ‘quantize’ put a low number like 1. This should give you black and white.
    Hope this help.
    grafxflow
    grafx that flow!
  • Jonas Espinoza
    February 1, 2007 at 2:07 am
    thanks, but with the sketch render tag, with allow lines selected, i still see the base shading for the object
    i made it work by applying a transparent material to the object with the sketch material. from what it sounds like this is somethign i can do through excluding.
    where exactly is that- sorry i didt follow when you said it first.
    thanks
