Activity Forums Adobe After Effects Sketch Effect
  • John Dickinson
    August 3, 2005 at 11:47 pm
    The animated strokes can be created using masks and the Stroke effect (EFFECT > RENDER > STROKE). Try playing around with the Start and End parameters. You can roughen up the lines using Roughen Edges (EFFECT > STYLIZE > ROUGHEN EDGES). Try Block Dissolve (EFFECT > TRANSITION > BLOCK DISSOLVE) to reveal the images. You can grade the footage using something like CC Toner (EFFECT > IMAGE CONTROL > CC TONER).
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Jmillz
    August 3, 2005 at 11:49 pm
