Activity Forums Adobe After Effects sketch draws itself
  • sketch draws itself
    Posted by Eugene Sergienko on May 11, 2020 at 11:39 am
    Hi everyone,
    First of all, please forgive my English, it is not my native language. I’m a novice with AE too.
    I’m working on an architectural presentation. There is a drone shot and some sketches on top of it that show the future area development. I need to animate those sketches which I receive as Photoshop layers.
    What I’m willing to do is to make the lines draw themselves like they are rapidly drawn by hand.
    I’ve tried using Auto-trace, then making all the masks Intersected, generating strokes and then keyframing them.
    The result was not perfect (Auto-trace draws masks not ON the lines but kind of between them) but good enough.
    However when I tried to export the composition I got this.
    I’ve been browsing all over the forum and youtube and couldn’t find a solution for this not so unique task. A link to a tutorial or an explanation as detailed as possible would be much appreciated.
    Richard Garabedain replied 6 years, 4 months ago 2 Members · 1 Reply
  • Richard Garabedain
    May 11, 2020 at 7:39 pm
    i think if you just increase your stroke size you can fix it pretty easily and it will still look nice…you could also increase the stroke to a even bigger number and just use that as a luma matte for your actual layer. Now your psd. check to see if its in rgb ..or you know what just export a few pngs of your layers..they have alpha channels and will be easy to use and will get rid of your strange “missing” files
