Activity › Forums › Maxon Cinema 4D › Sketch and Toon Lines Cut Off / Hidden
  • Sketch and Toon Lines Cut Off / Hidden
    Posted by Josh Penn on April 13, 2022 at 11:00 pm
    Hey there,
    I’ve come across this issue during an animation where the sketch and toon lines don’t fully outline the object. See the attached image where there’s a chunk of the S missing.
    This only happens very early on in the animation and for a few frames. By the middle/end of the animation, it’s fine.
    I’ve tried the other S&T line options, such as Angle, changing it’s Min/Max, with no luck.
    The problem persists, even when I move the camera to a different position/angle.
    I’m stumped!
    Edit –
    Okay, I’ve just discovered it seems to be an interference from the other objects (which don’t overlap), once I turn those layer off, the S&T lines reappear. More screenshot added. Anyone got any ideas how to resolve?
    Josh Penn replied 4 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
