Activity Forums Maxon Cinema 4D Sketch and Toon hand drawn preset
  • Sketch and Toon hand drawn preset
    Posted by Simon Bronson on May 9, 2005 at 12:36 am
    Folks,
    I’m applying a Pen (hand drawn) preset of sketch and toon and am trying to minimise the amount of flicker from frame to frame on an object which is coming towards camera. I’m restricting the thickness modified to distance an also make sure I’ve got a 0 variation seed and set to static in the Render tab. As far as the object goes I’m applying it to the folds, creases and border. Neverthess its flickering like crazy between frames. Is it possible to get this kind of line style without it going crazy in an animation?
    cheers,
    simon
    Adam Trachtenberg replied 21 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 9, 2005 at 7:26 pm
    Here’s a post I clipped with some good info. on controling flicker. Unfortunately I didn’t clip the author’s name, but I think it was Tim Clapham:
    “if you need strokes, and have flicker issues, you best bet is careful tweaking and lots of tests. the options to best tweak are:
    1)Join limit
    2)START + Angle
    3)filter
    4) END + length and angle
    These all control how the Strokes are created from the lines detected in terms of angles and such. It’s a sort of guessing and test game figuring out the ideal angle for the optimal results. While a test on a still may show no difference between a single degree angle, it could make a huge difference in an animation between a line joining another line or not.
    Also, be really careful of the combine function in the lines tab of the render settings and sketch tags. This setting combines lines of different detection methods with the same shader. While this I once thought was always a good thing, I’ve since discovered a lot of popping is cause by a line from the outline meeting a line from the folds making a single stroke when at just the right angles when using combine that of course wouldn’t if not combined. this can cause popping as well.
    If your using distort, be really careful to test whether closing strokes will work or not, neither closing or opening is perfect so its really dependent on which is less worse in terms of popping. This isn’t a huge contributor to flickers and pops, but it can be on occasion.
    A good piece of advice is to also try to avoid strokes that don’t match on both ends. like a stroke that is thick on one end and thing on the other. The less contrast before the start and end of a stroke, the less distinct two unconnected strokes will show.”
