Activity Forums Maxon Cinema 4D Sketch and toon appled to polygon selection
  • Sketch and toon appled to polygon selection
    Posted by Josh Van praag on July 28, 2008 at 6:45 pm
    I have a train where I want the metal casing to be gray and the windows to be white. The lines aren’t a major issue, pretty sure they’re all the same. I have a polygon selection set for the windows, but I can’t figure out how to apply the sketch style tag only to this polygon selection?
    Adam Trachtenberg replied 18 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    July 28, 2008 at 9:39 pm
    You can’t isolate shading to a selection with the style tag. I would recommend turning off shading in the sketch effect and using regular materials/selections with the appropriate sketch shaders for the color.
