Activity › Forums › Adobe Photoshop › Sizing file dimensions on Epson Stylus Photo R220
  • Sizing file dimensions on Epson Stylus Photo R220
    Posted by William Mcqueen on June 2, 2006 at 12:30 pm
    I’ve had reasonable results from printing both printable CDs and DVD-Rs as
    well as 4×6 prints using this inexpensive printer.
    However when I print from photoshop, photoshop always clips a portion of the image around the edges,
    i.e. doesn’t print the whole image eventhough I’ve set it exactly to 4×6
    in the case of prints, or the images I want to print on the CDs and
    DVD-Rs.
    How do I calculate the “real” image size the print should conform with for
    printing the “entire” image to these media? Is there a table anyone can
    think of? Like 4×6 is really= to….
    Thanks for your collective wisdom.
    Bill in Toronto
    Axelmedia replied 20 years, 2 months ago 3 Members · 4 Replies
  • Richard Harrington
    June 2, 2006 at 12:34 pm
    Check out Print with Preview command and also look at your image size to ensure how big it really is
    Suggest if resolution baffles you, pick up “Understanding Adobe Photoshop”
  • William Mcqueen
    June 3, 2006 at 8:19 pm
    I believed I was asking about a specific printer as in the header, howeverwhen I print from photoshop, photoshop always clips a portion of the image around the edges, i.e. doesn’t print the whole image eventhough I’ve set it exactly to 4×6 in the case of prints, or the images I want to print on the CDs and DVD-Rs.
    The above was the question I was posing. I always use preview, and I do believe I understand resolution issues, but I do not understand why photoshop clips/crops a actually sized images of 4″x6″ when sent to this printer for printing on 4×6 paper.
    I was also wondering if anyone knows of an excellent discussion group for Epson printers?
    Bill in Toronto
    June 3, 2006 at 8:53 pm
    You are coming off a bit snotty…. I of course say you were using a specific printer…. msot do not use Print with preview (and you can also choose scale iamge to fit media from there or center it). If you need a psecifc forum on Epson… try theit site.
  • Axelmedia
    July 15, 2006 at 8:49 pm
    Hi, I am having the exact same problem (Photoshop with Epson R200). I’m wondering if this is documented anywhere, either on Adobe’s or Epson’s site.
