Activity › Forums › Apple Final Cut Pro Legacy › size of project
size of project
Posted by Devon Leesley on September 23, 2010 at 12:06 pmMy project is 56KB. When I send it to Quick Time Movie it ends up 3.87GB. When I import it to Studio Pro it rings up over 18GB. All new to me. What’s must I do? thanks.
Devon Leesley replied 15 years, 11 months ago 3 Members · 17 Replies -
Jerry Hofmann
September 23, 2010 at 1:04 pmThe project file size has very little to do with the size of the QT movies you export from it. QuickTime movies of the same program can be of various sizes depending on the codec used to create them as well, so I’m not sure I understand where your problem lies. How to fit it all on a DVD in DVD SP? If so, then you need to compress your project using an MPEG 2 compression which will make the program work and fit on a DVD. These MPEG files can also be of different sizes even with the same program. The data rate chosen for the compression will determine the actual size of the video files.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
Rafael Amador
September 23, 2010 at 2:39 pm[devon leesley] ” When I send it to Quick Time Movie it ends up 3.87GB. When I import it to Studio Pro it rings up over 18GB.”
This is something difficult to understand.
Is the first time I heard that DVDSTP increases (multiply) the size of a file.
rafael -
Jerry Hofmann
September 23, 2010 at 3:47 pmDVD SP doesn’t make files larger. NO software simply opening a file will make it larger.
If you export a self contained QT movie using current settings, the file size will be constant no matter where it’s opened. Non self contained movies will always hold the audio mixed down, but can change size because they must contain renders of un rendered material from the sequence. So they can be of various sizes, and different codecs will make files of various sizes…
Jerry
Devon Leesley
September 23, 2010 at 6:21 pmAppreciate your guidance. Now if I can just figure out the steps for making it ‘self contained’ I may be home. Again, all new to this 60 year old. thanks
Jerry Hofmann
September 23, 2010 at 6:40 pmChoose file/export/quicktime movie…
Then click ON the “Make Self Contained” option. It will be a large file…
Then in DVD SP, open it’s preferences, and set the MPEG compression there… it will make the file small enough to fit and be compatible to play a standard Def DVD.
If you’ll post the length of your program, I can help you with what settings to use in DVD SP’s compression settings found in those preferences.
Jerry
Devon Leesley
September 23, 2010 at 6:55 pmAppreciate you indulging me. We filmed the movie with an HVX200 in HD. So we’ll be needing the final product in HD. I am taking Apple classes in Omaha. Between their help and yours we shall prevail.thanks
Rafael Amador
September 24, 2010 at 1:24 pm[devon leesley] “. We filmed the movie with an HVX200 in HD”
Hi Devon,
I guess (I don’t use it) that your 3.87GB movie is DVCProHD.
That has a data-rate of around 100 Mbps.
You can compress that a VERY high quality making the file 5 folds smaller.
How do you intend to play your movie?
From the computer, a disk?
Rafael
PS: I’m still wondering how you got 18GBs from 3.87GB in DVDSTP.
DVDSTP makes only MPEG-2 and the -
Devon Leesley
October 11, 2010 at 2:41 amIt is our own movie we filmed. Will go to dvd for a master.
Devon Leesley
October 11, 2010 at 10:52 pmI’m doing something wrong. I sent movie to Quick Time as ‘self contained’. It ended up 95 GB’s.
Jerry Hofmann
October 12, 2010 at 12:18 amThe movie is DVCPROHD in 1080? and how long is the edited film?
Jerry
