Activity Forums Adobe After Effects Expressions Size of Ellipse
  • Posted by Jakob Wagner on April 2, 2016 at 9:47 am
    Hi
    I’m using a script to add a shape layer with an ellipse. I can not figure out how to set it’s size. Not even after reading other posts…
    This is what I am trying:
    var l = comp.layers.addShape();
    l.name = "Ellipse";
    var g = l.property("Contents").addProperty("ADBE Vector Group");
    var e = g.property("Contents").addProperty("ADBE Vector Shape - Ellipse");
    g.property("Contents").addProperty("ADBE Vector Graphic - Stroke");
    l.("Contents")("Group 1")("Contents")("Ellipse Path 1")("Size") = [300,300];
    The last line doesn’t work. Can anybody help?
    Do any of you know of a reference for this “ADBE Vector” system?
    Jakob
    Jakob Wagner replied 10 years, 5 months ago 1 Member · 1 Reply
  • Jakob Wagner
    April 2, 2016 at 9:56 am
    Sooo.. Sometimes when you post after 2 hours frustration you figure it out 5 mins later. 🙂
    This is the solution:
    l("Contents")("Group 1")("Contents")("Ellipse Path 1")("Size").setValue([300,300]);
    I would still like to hear about that reference though.
