Activity Forums Maxon Cinema 4D Size of document
  • Size of document
    Posted by Tim Glidewell on January 4, 2010 at 5:42 am
    How Do I know what size to make my objects. I can zoom in and then they look big, but how do I know what size to start out. In the end I will be importing to FCP in SD format so do I work with pixil 640×480, in C4D or inches or what. I tried to put some video on a object the video was all big I assume my objects are way to small when I’m starting out. thank you for putting with my qustations
    Adam Trachtenberg replied 16 years, 8 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 4, 2010 at 4:44 pm
    The only thing that matters in terms of output for your editing/compositing application is the render size, so pick the same resolution in render settings that you intend to output from FCP.
  • Tim Glidewell
    January 4, 2010 at 5:28 pm
    Thank you. So just so my head is wrapped around this. It dose not matter at all how big or how small my scene is in the view port while I’m working on my project. But when I render I pick the correct setting for output ie 640x 480..
  • Adam Trachtenberg
    January 4, 2010 at 7:13 pm
    Yes, exactly.
