Activity › Forums › Apple Final Cut Pro › Single Viewer: Eyeballing Match Frame
Posted by Sandeep Sajeev on September 12, 2012 at 4:13 pmI have an offline that I need to recreate. No EDL/XML, timecode ref, nothing, just a Quicktime file and DSLR rushes. Trying to manually match up a frame from the raw footage to the offline is really annoying without Dual Viewers.
Add in the fact that there’s no way to change the opacity of a clip without going into the Video Effects Menu, and I have to say I’m not enjoying FCPX much today.
Sandeep Sajeev replied 14 years ago 5 Members · 7 Replies -
Patrice Freymond
September 12, 2012 at 5:43 pmHow about editing the clip above the off line, crop clip where most visually convenient to find match, then slip tool to visualy match. zero crop and you’re done. not the most fluid of workflows but at least you don’t have to expand menus, colapse tracks or else…
hope this helps
Patrice Freymond
Editor Certified Trainer FCP7/X
Post ConsultantAlways learning…
Sandeep Sajeev
September 12, 2012 at 5:58 pmThe offline is the Primary Storyline. I’m connecting the rushes to the offline in the appropriate places.
Didn’t think of using Crop, thanks!
Still going to be painful though. Anyway, I’m resigned to this session sucking so I’ve come to terms with that at-least.
Don Smith
September 12, 2012 at 7:28 pmYou’re almost there. If you have the offline in the Primary storyline, then edit in a short clip that’s just close but not exact to somewhere in the middle of the underlying clip. Set it to half opacity and then, with the upper clip selected, press the comma and period keys to slide the connected clip until you see a match. Once the match is made, expand the in and out of the upper clip as needed and restore it to full opacity. That’s how I would do it even if I had dual view screens but one on top of the other is still better than comparing them side-by-side.
NewsVideo.com
Sandeep Sajeev
September 12, 2012 at 7:45 pmI was tempted to go back and cut this in 7, but then I remembered all the clicking I’d have to do to load the clips in to the Viewer.
Now that the iOS stuff is out, hopefully 10.6 rolls out soon. The Dual Viewers don’t even need to be ‘re-imagined’ or ‘revolutionary’. They just need to be 2-up to make me happy.
Bret Williams
September 12, 2012 at 8:26 pmSurely there’s someone on this board that can tell you why it’s much more efficient to do this in X with a single viewer. You’re just not holding it right.
Jeremy Garchow
September 12, 2012 at 8:35 pm[Sandeep Sajeev] “Add in the fact that there’s no way to change the opacity of a clip without going into the Video Effects Menu”
Select clip, Control-v, find the opacity parameter, open it, drag down the opacity bar.
I think you can copy/paste the opacity effect as well (command-option-v), as long as that’s the only thing you need to copy/paste.
Jeremy
