Activity Forums VEGAS Pro single sided dual layer DVD burning
  • single sided dual layer DVD burning
    Posted by Pete Locascio on January 30, 2009 at 6:39 pm
    I have occasionally adjusted the bit rate of a large project in the “optmize disc” feature of DVD Architect 5.0. The result, depending on the size of the project, was a somewhat degraded image. I have a burner, that the specs say, will burn a single sided dual layer disc. Has anyone out there burned a project on a single sided dual layer DVD+R in order to get better results with a large project? If so,besides using the correct settings,what are some of the things you need to do,such as chapter placement,in order to get a project that transitions smoothly from one layer to the next? Thanks!
    Pete Locascio replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
