Activity Forums Apple Final Cut Pro Legacy Single image motion is very choppy
  • Single image motion is very choppy
    Posted by Filip Milovac on January 26, 2012 at 2:36 pm
    Hi, I have a little problem, finishing a video for a client and I added a few pictures from a shoot, did a simple motion with key frames on each side of the picture, but when I export the video the pictures and very choppy and not smooth. Please help, what do I do???
    Scott Maida replied 14 years, 8 months ago 2 Members · 4 Replies
  • Scott Maida
    January 26, 2012 at 10:04 pm
    I have the same issue, and I was just looking around the manual to see if I can find a solution..
    good luck to both of us.
  • Filip Milovac
    January 27, 2012 at 12:07 am
    If I find a way, will definitely post. Good luck to you too.
  • Filip Milovac
    January 27, 2012 at 10:58 am
    Mate I use Premiere Pro, either way use high frame rate from the start, I think that could be the problem. Hope it works.
  • Scott Maida
    January 27, 2012 at 3:59 pm
    Thanks. It worked fine after exporting to quicktime…. but how do you change the frame rate for future purposes?
