Activity › Forums › Avid Media Composer › Single Field Freeze Frame (use 2nd field??)
  • Single Field Freeze Frame (use 2nd field??)
    Posted by Jason Brown on December 20, 2005 at 5:44 am
    Hey Everyone,
    I have a HUGE beta hit (it is only on Field 1) on a standup that I need a guy on camera…I can’t cover it. I have had success in the past of duplicating a frame before or after and it is barely noticeable…but I was thinking (look out!)…I can use “duplicated field” in my freeze frame option. So is there a way to duplicate the 2nd field (where the beta hit doesn’t exist)???
    -Jason
    *going to run the head cleaning tape through the cam tomorrow!*
    Bill Stephan replied 20 years, 9 months ago 3 Members · 2 Replies
  • James Burke
    December 20, 2005 at 2:49 pm
    When I’ve needed to do that in the past – I’ve exported a still image, used the video filter deinterlace to remove first field in PhotoShop and then imported that back in.
    James Burke
    Creative Director
    mBlaze Multimedia Design, Inc.
    http://www.mBlaze.com
  • Bill Stephan
    December 20, 2005 at 4:49 pm
    If you’re on an Avid system with the Scratch Removal effect, you can paint in a portion of an image up to +/- 3 fields away from the problem field. Or do a similar fix in After Effects. Or use Photoshop or another painting tool as James pointed out. So pick your favorite tool and go at it!
    I once painted over several thousand negative dirts in a Quantel Paintbox for a made-for-tv movie project.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
