Activity Forums Avid Media Composer Sing Roller Edit Error
  • Sing Roller Edit Error
    Posted by Jordan O’leary on February 12, 2006 at 7:24 pm
    I do a single roller edit on A side with all of the sync locks on and I try to drag it to the left so as to bring everything from the right over to the left to close up a gap. When I let go of the mouse I get that “DUNK” sound and nothing happens. When I drag it ovr to the right, however, it works fine. The only way around it for me is to turn off all of the sync locks, make edits on ALL the tracks including the fillers, select the A side of ALL the edits, and trim it that way. It works when you do it that way for some reason. Needless to say this is a pain, I’d rather trim the A side with all the sync locks and have everything move that way, what’s going on?
    Michael Phillips replied 20 years, 6 months ago 2 Members · 1 Reply
  • Michael Phillips
    February 13, 2006 at 12:17 am
    Has one of your clips run out of media on one of the tracks?
